Here are some closeup of the latest details.
Yeti skull driver head on the wild willys body. Strapped in with harnesses by me.
Yeti fuel cell for the radio along with an Exo terra battery, nos bottle and some yea racing fuel tanks attached to the tsc tool box
Passenger seat with a harness and the minimum of decals added.
I have had some major servo problems. My hh v2 servo lost the gears again. No idea how or when. Parked the rig and went to drive it today with the servo jacked up again. Dropped some serious coin on a new one. In the mean time back to savox 1230.
I figured while it was down I might as well waterproof the kms servo winch.
I decided to do it a little different than metal masher and szczerba. I just added a seam of silicone to the motor face then sealed around the motor can and the case and then the endbell. Should work as I've already had this thing dunked and the winch keeps working.
Also greased up the drive to the spool to keep it moving free.
On the freespool shaft I added the typical oring.
To try and keep the bearing for the output shaft clean (as it needs to slide in and out of that bearing to engage/disengage). I added an oring and a washer to the outside. To keep pressure on that I put a pen spring on the shaft and set one of the collars I had to preload it. This also helps add a little spring pressure to get the winch back to the engaged state.
I also waterproofed the output on the other end of the servo the same way they did, just no photos.
