SimoCanto86
How do you calculate body and bed points for a truck like this?
"Mouse" - Page 6
I guess only -4 points for abs cab (even if it's extended)?
Is the rear considered as a flatbed, so -3 (it has a metal fame under the wood bed) and -2 for metal rollbar in the bed?
I will put inner fenders in the front, but what if i close the gap between the bed and the frame rails in the rar with a flat black plastic panel? no inner fender points for it?
How do you score a truck body like this?
https://www.youtube.com/watch?v=ygdVz_Qgb-w
full rigid body, or hard body cab + flatbed?
what if the bed has side rails + tailgate?
I'd like to ask you also your point of view about a particular italian technical issue: we have some drivers running on their most extreme trucks a system for variable ride height in the front.
It uses a servo winch connected to the front axle with a cable, so you can use for compressing front suspension and keep your front end down on steep climbs minimizing the risk of a rollover.
Something you could do by connecting you winch to the front axle on a 1/1 rig.
is it sorrca legal to use it during the course to adapt your truck height to the obstacles? in which classes is it allowed?
thank you so much
"Mouse" - Page 6
thank you so much
