The issue is these aren't knuckle weights.... their weighted knuckles.Rules state "no comp style". Please allow all or nothing.
(But I am not the sorrca committee) so... lol
Sent from my SM-N900V using Tapatalk
Are these going to be (scale rules) legal?
Yes, a vacuum formed body is considered a hardbody if it's made from a material other than lexan.
Not a hardbody in my book.
Not sure, I'd have to look into them.
YesIs a spare rewarded scale points without a rim?
We need clarification.
SimoCanto86 (Member of the Regional Committee SORRCA Italy) in the post number 93
has asked you if a vacuum formed body in ABS (thickness of 1.5 mm ) is hardbody or not.
Same request for commercial Kamtec ABS vacuum formed body.
Unfortunately you have responded in different ways:
Post number 95 War Pig writes:
Post number 96 Big Daddy writes :
hardbody: can a 1.5/2mm thick abs vacuum formed body like this:
or like the ones from kamtec...
For us the answers are contradictory, and the need to have a clear response.
To my personal opinion, it's right to reward the hard body (ABS manufactured by molding) because they limit
the performance due to the high weight and stiffness.
In the case of vacuum formed body in ABS , the weight is lower than a body lexan
(the specific weight of the ABS material is less than the specific weight of Lexan material)
and they are not as stiff as the body manufactured by molding.
I ask you kindly to provide a single answer, we have already seen some manufacturers declare
these vacuum formed ABS Body SORRCA Legal...... but we would like to be sure of your judgment.
Thanks in advance
Spare tire is rewarded under Functional Accessories, doesn't seem very functional without a wheel. I would not award points for it.Is a spare rewarded scale points without a rim?
Under the current rules, bodies other than Lexan are eligible for hardbody points.
It is my opinion that they shouldn't be but that's an argument for another day. "thumbsup"
The guys at ecsc gave me the points. No where in the rules does it state it needs a rim.Spare tire is rewarded under Functional Accessories, doesn't seem very functional without a wheel. I would not award points for it.
Plus I've seen videos of guys Changing tires (without rims) on the trails
I am from ohio.... I can't tell you how many guys I know right now with a tire without a rim floating around the bed of their truck.
Again,it's not spelled out in the rules what constitutes a hardbody. As of right now, a vacuum formed ABS or styrene body can receive hardbody points. It's something that is being discussed and voted on in the scale rules committee. There's a REALLY good chance that any vacuum formed body will not receive hardbody points in the upcoming future. The scale rules will be quite a bit different for 2017.....just keep that in mind.
Under the current rules, yes, they would be legal.
I'll leave my personal opinion out of this...
Is this on the list of things to be looked at for 2017? (crosses fingers)
I was hoping for the opposite actually. These huge weighted knuckles differ from knuckle weights in name only.What, to make knuckle weights legal? No it's not.
I think they should bring back knuckle weights.I would definitely support that if/when it comes up, but it's not currently on the already lengthy docket.
