The best Berg gears ever made are finally here!
For gear info check this YouTube video starting at 12:00
https://youtu.be/1VbVoj3RiFo
What makes these the best Berg gears?
Made by a well known gear maker
These gears are made in the USA by Robinson Racing. When I wanted a well made gear, I didnt want to take some chances with a random guy or some manufacturer in China who had no first hand knowledge of gears. Robinson Racing has over 25 years of experience making gears and has made 1000's of them. I knew when I talked to them and told them that I wanted "the best gears that money can buy" that it was going to be the correct way to get these done. They really helped me the whole way from dealing with their proprietary alloy, to hardness to design. When I asked for the 48p large 2nd gear, I know for a fact that its going to mesh well with other brands of 48p pinions. If you look at the pitch of the tooth, you can see a huge difference from the SDS gears to the SAF gears. Look how much bigger the tooth is and how good the SAF gears profile looks! I am more than satisfied with the quality of these gears and I think you will be too! And one of the best parts? I can have as many of these gears made as I want! The Berg is safe now!
Strength and hardness
When making a gear, not only do you want them to be strong but you also need them to be hard so they will last. IMO, we have had Berg gears that are strong enough but for me, they never have been hard enough. I have always been able to wear a set out in about 3-6 months depending on how much I am driving. Those days are past us now. Gears are the heart and soul of the Berg. They are what makes the Berg the best RC crawler ever made. Now, the best gears just got that much better. These gears can be passed down to your grand children.
Lightweight
These are some of the lightest gears ever made. Take notice of the small gears. They have been gun drilled to reduce weight. All the large gears have had a maximum amount of weight taken out all while retaining as much strength as possible.
Big pins mod from the get go
All gears have the 2.5mm pin vs the 1.5mm pin that comes stock. Nobody will be able to break these huge pins!
48p large 2nd gear
No more crazy pinions that you cannot find at your local hobby shop! These large 2nd gears are made with the well known 48p so you can run pinions from many different brands, many different tooth counts and many different materials and all are ridiculously easy to find! Now we will have the option of even smaller pinions and since the pinions can be made from a better material and harder, they wont wear out. This is a huge one!
These are on sale and shipping today.
https://dluxfab.ecwid.com/#!/SAF-Berg-gears/p/22122165/category=1515294
Lightweight
48p large 2nd gear
