TacoCrawler
Pony up for the Savox SB 2290 SA and you won't regret that purchase.
Wow, what keeps failing on the Holmes ones?
Do you own a 2290?
I ended up useing the aluminum buckets i made at work and they worked really well. Paired them with some 10mm super bright leds, i do wonder if they are almost to bright. I think the outer diameter of the light bucket was close to 1.5 inches. Wife has a cj7, never thought about turning a yj into a proper cj.What did you wind up using for headlights. I have a SWB TF2 with a Tamia YJ body. I did not like the square headlights so I made a new grille with round headlights. Now it looks like a CJ7. I have a 79 CJ 5 so.... close enough. Better than square. I drilled 3/4 in holes and fit Axial buckets in them with 5mm LEDs. I also found LED lights at Wally World that work on 12 volt (3s) they have a pretty good selection of various LEDs. The ones that fit in to dome lights also look promising. The ones I bought are .812 inch with an aluminum housing that may work for you also. Very nice rig so far. Good crawling, later
I used a Savox SA-1231S, 444 oz servo on my 1/6 scale 14 lb Hasbro Jeep, and it turned the 2.2 ProLine Super Swampers without any problems, even in a bind.
