All unpacked and squared up & leveled getting ready for the 1st print
I printed the included Bot 1st as a test piece. All in all I was very happy with the results. I can see in the back where it's not perfect and the ears also could be better. I'm going to print the included unicorn and see what it looks like.
Watch your hot end temp, and if it swings more than a few degrees you will need to tune your PID. I just got the same machine under a different brand and the PID tune was terrible, 10c plus/minus swings. Get your computer hooked up to it via USB and execute the Gcode through Cura, repetier, or whatever your choice. Guide found here http://reprap.org/wiki/PID_Tuning
After that, I would recommend you tune your E-steps to ensure it is pulling the proper amount of filament. Mine was off by 6% from the factory, leading to constant under-extrusion. The reprap website should have a writeup about how to do that as well.
Once PID tuning is done and e-steps are calibrated, everything else will be much more likely to yield quality and consistent output. This should be done on all new budget machines, and any time a new drive or hot end is installed.
