soze
G
There are no proper rocks near me locally so I jumped in the old Porsche and blasted 50 miles to a place I hadn't been before.
Whatcha got? 964,993,996,997.1-2,991.1-2?
G
And where do you manage to stow 3 rigs in it?Whatcha got? 964,993,996,997.1-2,991.1-2?
944 S2...Its a late one with Bridge Spoiler. Bought it in 2013..its cost me a fortune but I love it. Only 4 left in this colour in the UK. Took it to the ring last year which I really enjoyed.Whatcha got? 964,993,996,997.1-2,991.1-2?
I have the Mamba monster X in my bomber with a 2200kv with the aux mode setup the same and that doesn't budge. It can fit 5 trucks in quite easily. Handles really good aswell, pic is from a track day last year at Bedford...... At the ring my 1st ever lap was wet and I spun at Kallenhard. 2nd lap was wet and I still managed a 10:10 according to the gopro. First dry lap was number 3 the next day and it was a 9:16 and my 2nd dry lap gave me a 9:06...not bad for only 200bhp in a 25 year old(then) car and so few laps.And where do you manage to stow 3 rigs in it?
The Mamba X should have no problem providing a strong drag brake, so my guess is you're on the money with it being the motor. Though make sure you have the Rock racer/crawler mode set up right, I struggled a bit to get that mode working right initially.
I used that same ESC with the HH puller pro 540 (in my Wraith) and at 100% drag bake its too much for everything except for going uphill, I have it set to 50% for everything else and 0% with reverse lockout for bashing.
Just had this through from Junfac....new CVA joint to try. To be fair with glue and heatshrink I'm yet to break another pin.
Dear James
We send out your replacement part today by Korea Post.*
We send you new joint part so you can try it.*
New joint can hold the pin by socket set screw,*
and also include some repair pin's and ring's you can use for repair.
Hope you like the new joint.*
Sent from my SM-G935F using Tapatalk
I loosened the bearing caps and unseated the ring and differential a little bit. This helped quite a bit but still seems a bit too tight compared to rigs I've built in the past. They seem to spin smooth and quiet with wheels/tires on but I can't spin them with only hubs installed. :roll:
I placed a lexan piece under the rubber band just a little bit smaller than the battery tray. This way I can slide my battery under the lexan piece and it won't get caught on the rubber bandAbout a "practical" thing, what have people done with the battery compartment? I don't have the interior tray in yet so I can work the battery into place better, but... the rubber band that secures the battery into place is such that I can't just push the battery into place, I have to lift the band for clearance so I can push the battery all the way in without snapping the band because the end of the battery just pushes it along. Removing the band doesn't seem like a great idea since the battery would then be rather loose, even with the tray in place.
Another related thing is the battery connectors. As far as I can see with the tray in place the battery has to be connected while outside car so the battery wires have to be long enough to reach there, seeing as the ESC is on the "far side" from the battery door? I'm not even sure where I'm going to route them from yet. Though I also have to route the receiver wires since the receiver will be on the interior tray rather than under the hood.
Oh, and I did just put in a stronger 20kg steering servo because I thought the previous 13kg one was having trouble with centering. But seems that rather the perceived oddities in steering centering are related to bump steer? With unloaded suspension the wheels go to the left, with loaded suspension to the right. I must say I never noticed this on any of my racers, and the product description even says the effect is "minimized"... seems like it is anything but! :razz: I suppose it's not so critical in actual driving in itself but it does make it much harder to calibrate the steering angle optimally to avoid stressing the axles.
Hmm, one way to do it I guess, even though it'd certainly lessen the contact of the rubber band with the battery and thus the "retaining power" especially for sideways movement. I wonder why couldn't they just make the rear-side edge of the tray higher? Oh well. Another thing I considered is making ramp-type piece that would lift the rubber band on top of the battery when pushing the battery in, but even messing with that every time that you remove/install the battery seems annoying.I placed a lexan piece under the rubber band just a little bit smaller than the battery tray. This way I can slide my battery under the lexan piece and it won't get caught on the rubber band
Yeah, actually I just ran into this problem too. Connecting the battery before pushing it in prevents pushing it in because the connectors hit the cage. I even changed to low-profile connectors but those kinda fail at being low profile because they don't go fully into the battery but stand out an unnecessary 3mm or so, without that it'd work. I guess I gotta try to modify one of the connectors.I've been wondering what people do to connect their battery after they've boxed in under the hood, must be some trick to make that work.
Kinda caught me by surprise, I've seen people discuss it with non-crawlers I have but as mentioned I've never noticed it on them myself when calibrating steering. And I've got 10 non-crawlers. I guess this type of suspension & steering setup really brings it out.The bumpsteer isn't something I've noticed when crawling, but at bashing speeds its likely a lot more noticeable, its just something that comes along with a chassis mounted steering setup.
When I was testing the speed outside I didn't experience any bothersome levels of torque twist using a 3300kv motor with 2S (which is as fast as I plan to go), but of course traction was low on snow/ice which affects things. And well, I was driving 3WD at the time (axle issues out of the box, should be remedied in a few days). I have currently no plans for the roll bar due to the price plus probably not needing it that much for my driving. I suppose if twist turns out to be a problem in practise I could look at the shocks if they don't hamper crawling, they look cool and are half the price of the ARB.Dual shocks in the rear are pretty nice in combating a bit of the massive torque twist this thing has, but the anti roll bar does a much better job at that.
Thankfully the new shift servo (JX PDI-6221MG) seems to stay silent. The new steering servo, not so much. Maybe I'll switch that to a JX too when I get some more.The shift servo only seems happy in 1st gear, it seems no matter how its setup in dig and high gear the springs are always pushing back against the servo.
All-around all-terrain, basically. I guess if the stock gears explode I'll look into how much it'd cost to go single-speed, or just buy the metal gears.Going single speed with brushless might be nice for the sake of simplicity, I guess it just depends on how you plan on driving, crawler or basher ect.
I get dig, though originally I didn't realize the rear wheels were supposed to lock so I only had freewheeling rear. But after reading up I realized it was meant to lock the rear and adjusted servo endpoint accordingly and it works fine. Maybe it's just my lack of crawling experience but I just honestly don't see when and where I'd use that mode. Dragging a locked rear around? Eh. I'd rather just have the FWD if need be but I'm not sure if that would cause improper partial gear contact and thus stripping?Havent really had much luck with being able to get DIG...I can get freewheeling, but not quite full DIG. 2nd will go in usually on 2nd attempt when rolling at very slow speed.
I definitely noticed the Hi/Lo speed difference with the 3300kv/2S even if it wasn't earth-shattering.With a 3800KV on 3S with an 18T pinion, you can crawl really well and have reasonable speed...havent noticed much difference in top speed on 1st and 2nd gear.
