One big question - will it get OD and/or UD gears? That's a must IMO.
Yes, we will have an overdrive gear set for the front axle...just couldn't get it out in time. We'll have more info soon.
I think that they included a metal insert in the servo horn shows how much consideration they gave in this project.
Well done Axial. Lots to like here, glad it’s a kit!
Right on the website it says, "The battery tray is forward mounted, and located under the hood. The tray size is built for shorty packs, at a maximum size of 26mm x 98mm x 47mm."
That design was on the Losi Rock Rey and I'm guessing other Horizon vehicles. It makes the teeth stronger, but the rest of the arm is still plastic. An aluminum horn is a better choice. Not as big of a deal on 1.9 as it is on 2.2, but I'd still upgrade to an all aluminum servo horn.
I’m really not one to complain publicly l, but “boo, and thumbs down” on the shorty pack.
Here’s to hoping that modification is straight forward.
Is there any way to build this without dig (in the interim until a HV micro servo can be acquired).
Yes a spacer is included to "lock" it in 4wd.
I will note that the SPMSSX107 Servo from the is the only Micro servo that will "drop" right in. Can you use others yes but before there is a conspiracy issue (and something for Jato to complain about LOL), this little servo is metal geared and was the right fit and had more torque that we could source from our available vendors. The micro servo also has the base you need to fit the servo saver arm to connect to the trans to operate the dig.
AGAIN, yes you can use others but you will need to find a way to setup the linkage.
So if you plan to use dig, i would highly suggest getting a SPMSSX107 servo on order and depending on where you plan to run your receiver, get a 3" servo wire extension.
I'll post more tips in a dedicated thread at some point.
Rich
Ring and PinionRing & pinion or portal gears?
Hopefully these universals fit VP portals so there is an alternative that doesn't have craptastic steering. I'll be picking one of these rigs up and seeing what kind of angle I can get out of it...
Excellent! "thumbsup"
Considering preordering...
