Having a problem, and hoping to get some assistance. With the Capra being my first crawler, I'm also completely unfamiliar with transmitter settings for getting a DIG operational...everything else is functioning correctly, just not the DIG.
I'm using a Futaba 7PX. There's info in these threads related to the 4PV, which had controls (ie. switches) almost identical to the 7PX, but the menu system is entirely different.
In manually "playing around" work the DIG level, I can tell that it should be possible to set up a 3-position configuration, even though Axial's marketing is advertising it as a 2-position. What I was thinking is that one switch (such as PS1), with the 'Type' set to "Nor." (ie. like "on/off"), could operates the DIG arm for 4WD & FWD w/ locked rear. Then another switch (such as PS2), set as "Condition 1", could have the 'Type' set to "Alt." (ie. only activated when pressed down), which would move the DIG level to a preset 'mid' position for FWD w/ rear freewheeling. When PS1s pressed, it wouldn't matter if PS2 was 'on', or 'off', as the PS1 "Condition 1" would override the PS2 setting.
The problem is, I don't know how to set any of this up...as a 3-position DIG configuration, or as a 2-position. I've tried everything I can think of, as DIGs aren't exactly covered in the manual. I've tried calling Futaba, but the person I spoke with was unfamiliar with DIGs, and said he'd need to reach out to another tech who understands DIG settings...but that tech is on vacation.
So, can anyone help, please? A 3-position config would be fantastic (even knowing it would take two separate switched to operate), but, right now, I can't even figure out how to set up a 2-position. How to I set up things on a 7PX? Again, help...please?
