Cordless Screwdriver
I spent a lot of money for the cordless Dremel GO-01 driver. Had a clutch but even on the lowest setting it had way too much torque for plastic. Plus there were some other things that I didn't like such as the mechanism that in order to operate it you had to push down [rather hard]... no button to control the drive. So you had to push down hard to extract bolts as well as drive them in. The minimalist profile was nice... was able to get in tight places but for $40 it was a no-go.
After looking at a lot of other drivers ( most I felt were too much money, were overkill, or didn't have a clutch) I stumbled upon a cheap ( $14) Walmart Hyper-Tough driver ( 4vt lithium-ion) and let me tell you... I love this thing. On the down-side it is a bit bulky but it goes forever between charges, has an awesome clutch with very accurate +/- torque adjustments. It has an LED light which is a nice feature at this price ( not super bright but adequate for most situations where you need a little more light) and you can rotate the handle straight or angled. It also has a nice large ring so that you can easily/ quickly hang it up. The hex drive socket is magnetic too which may be obvious but maybe worth mentioning. I've been using this one now for probably 9+ months and no issues whatsoever. I also use it for other projects around the home when I don't want to mess with my larger/ heavier/ bulkier corded and cordless drills/ drivers. For the money... this Hyper Tough is well worth it and aside from being a tad bulky and not having a brighter light, is otherwise perfect for RC plastics and lighter-duty jobs. BTW, part # is AQ70008G.
I have had much success with this.
https://www.amainhobbies.com/muchmore-professional-electric-power-driver-mmrmmped/p742255
It has a very low torque clutch. You have to manually twist it to loosen some screws. Then zip the screw out electrically.
This has been a great gift to myself, especially when it comes time to change the foams.
Edit: I should also point out. I purchased a full set of bits. After a few tire unmounts and remounts trying to tune the foam, the 1.5mm showed wear. It even slipped once.
I immediately stopped using that bit and ordered a 10 pack of that size.
I also ordered a 10 pack of 1.27mm (.050") for the SCX24.
Thanks for the heads up! And it's available in my local Walmart (seems like a normally stocked item at all Walmarts). For $14 with a two year limited warranty, certainly easy on the wallet to give it a try.
I use this puppy right here. Found it on Amazon for $15 or so. It gets the job done, but it’s a little on the slow side. Also came with all these bits[emoji106]
Has an LED light.
I was looking at that Tacklife SDP50DC but it's currently $26 on Amazon. It's also 3.6vt which may be why it seems a little slow. They've got some newer models but they're closer to $30.
How do you like the inline version? I'm leaning towards Dewalt's pistol grip but haven't pulled the trigger yet. ... Get it?! Ahhahaha:shock:
The inline - appears to me - to be awkward to use vs the pistol grip. Tell me the pros/cons.
I need to get my hands on both and try 'em.
I couldn't find the pistol version locally. that is what I was going for. but this one is great. However I think the swappable to pistol grip version would be more comfortable to work with. Like all inlines, the can be a pain to use at certain angles, where the pistol grip is more ergonomic and gives less wrist stress.
I have two of the same Milwaukee M12 cordless screw drivers and I love them. Just an FYI however concerning the Milwaukee screwdriver. The motors are known for burning out relatively quickly so do a search on google and youtube for "Milwaukee m12 screwdriver motor replacement" it is not really a big deal to repair and replacement motors are under $10. But in the process of repairing my M12, I discovered that the motor is a standard 550 can size so I replaced the motor in one of my M12s with a Holmes Hobbies Crawlmaster Sport 13T. The only real issue was getting the pinion gear off the old motor so I could install it on the new HH motor.
My experience with Milwaukee consumer level drills/impacts is that they are garbage and that's being nice lol. Way better choices out there. I have an 18v Ryobi that has outlived all of them, we're talking 10 years with the same 2 batteries. Every Milwaukee I've had including the brushless have failed within a year of purchase.
Having said that I tend to wrench on my RC by hand. It's more satisfying to me and I'm never in a hurry. Plus you pretty much eliminate the stripping/over tightening aspect. I have a ratcheting screwdriver that takes all of the drill bits and its my go-to for all things tiny and fiddly. That and my trusty 5.5mm box wrench. I get the power tool thing if you are in a comp/hurry for whatever reason but imo nothing beats the feel of hand tightening for tiny parts.
I've had this small little $20 4V Skil for about 3 years now. The charge lasts forever , and has enough power for putting in any type of screw on any vehicle. It doesn't have a clutch, but I could care less. I drive a screw 95% of the way in and hand tighten the rest. I don't like to rely on a clutch, especially when screwing into plastic.
https://www.lowes.com/pd/SKIL-4-Vol...tery-Included-and-Charger-Included/1001863744
Sent from my LM-G710VM using Tapatalk
I know everyone has their own preferences but what I look for is the smallest drill with an actual chuck as I hate being limited to using 1/4" bits only. The tool I bought to drive screws now gets more action drilling holes.
I ended with a little Makita drill and probably spent more that I should have but its super versitile.
My next drill will have a Chuck just for this reason. I bought a set of 1/4" hex drill bits. The problem with this is they don't stay snug in the drill. There's a little play. Whenever I have to drill any type of hole, I have to run out to my truck and get my 19 volt drill out of my tool box that I use for work. It's not that often, just inconvenient.
I think that they are different tools for different jobs. A drill needs a strong drive. But is a bad tool for putting tiny screws into plastic because it tears them out.
A cordless screwdriver for putting tiny screws into plastic is not a good tool for drilling holes.
I do know that the MuchMore is great for screws in plastic.
fwiw, I only use the driver to accelerate removal or install of longer bolts. I start and finish bolts by hand.
Pretty much eliminates the stripping and crossthreading issues, but speeds up the process. unthreading 15mm bolts or longer is a pita by hand.
