I never said anything about Run2 making a different chassis design.
They are ALL different animals.
One thing you can do with a droop chassis, is easily limit articulation as well as unloading, this can be achieved with something as simple as a zip tie, or as complex as a winch. Not as easy on a sprung rig and down right impossible on a torsion. Either way, Highmark made a very good point, none of this force on the tires really matters in rock crawling since the terrain is so varied. The weight of the vehicle itself, and where that weigh is placed has FAR more effect on traction then suspension does.
You can limit the articulation on a Torsion. There is a few ways to do so. I can tell you haven't really set one up. Which thats fine. I haven't set up a Droop set up either. Thats why I asked this question as I have a few builds going on. But I never really got my answer.
You can limit the articulation the same way with either a Sprung or Droop set up. A Zip tie and a Winch would do the same things. Ones not any easier then the other as that goes. Know with a torsion it is harder to do so. It takes more time to dial in things like that on a Torsion chassis. Weight comes into play alot more on a Torsion chassis then any other chassis out.
Suspension does have alot to do with Crawling. But weight and balance is a big factor as well. Force on Tires is always important. It can mean the difference from lifting a tire or not. From getting traction to not.
Now how does a Droop set up work and Why? Doesn't the shock always want to stay closed. So then it would always pull up a little on the tire. What would make it better then a normal 4 link and Sprung set up? Whats the Disadvantages and Advantages? The way a suspension works, the Force thats applied and the Roll Center are all very important and have been brought up. But how do they factor between the two designs?
