best tranny for a super?
I have the emaxx with revo shafts at the moment but would like to go smaller. Would a VXL pede tranny hold up to supers?
I would try the Rc4WD V2 trans and punisher shafts.
you must be joking :shock:
that motor will eat it for early breakfast- Edit ok just looked at it, well it looks built stronger, might hold up
if you do try a rc4wd then only go with the new Heavy duty tranny
I put money on revo shafts over punisher shafts
I have used a emaxx tranny with great results with a outrunner BM16, it's just to big and terrible COG.
After breaking my rc4tranny, I bought an Axial tranny, to try out, but have not bolted it in yet
do you know if the revo shafts will clear the stock spur gear?
the V2 looks to have the same sized gears as the R2HD. Plus dual motor capability in the size of a pede. only time will tell if it will hold up or not.
I have had a R2 version 1 ever since they came out and have had zero issues with it. run everything for BL outrunners to lathes on it. must have been made from good pop cans that day.
Axial tranny
I have one in my super. They clear if you have the diff cup that comes on the spindle end of a Revo axleshaft. But I had a little issue with my tranny. I broke the output shaft that connects with my rear driveshaft. But I will try a different motor see if that helps and see if I break a little less parts.
