I haven't had much time to add to this. With Crawlalplooza coming up. I've been busy. We have also had rain for the last 2 weeks. I hate Rain....![]()
Ya I'm going to. The Leopards need one more run on them. Problem is the weather around here as been either freezing Cold or Raining. Which both will give different results from what I have already. So far the Leopards have pulled every line and some new ones. The only thing I'm not liking about them is the width. I wish they were 1/4in to 1/2in Narrower.You gonna be throwing the Leopards into the mix?
Are you going to try the Yellow X locks? just curious if the color pigment would make a difference. I'm running the X locks with stock foams at the moment under my Bully and like how the stock foam holds the sidewall so far. Do you feel the stock foam would be sufficient for the X locks?
VERY excellent write ups and testing. Thank You for all your hard work."thumbsup"
Yah,I would like to have seen the a little narrower myself.
Seems like they work better when they get scrubbed in too.
What foams are you using?I am running Nova's 2 stages in mine.
Using the same foams as well.
What happened to the Rover video? What foam setup was in the rovers to make them so tall and thin?
If I can get a set I'll test them against the Others, but I don't see them doing any better.
Got a set mounted to some 8-shooters, they are the same sticky compound as the black. Gonna get another pair and run'm on the Bully., Man these things flat out STICK to rocks.
