For laughs I though I'd list what went into the making of the Hybrid:
(4) Rc4wd 2.2" Rox Lox w/included foam.
(4) Vanquish SLW V2's with Wide front and narrow rear hubs. Black with Silver rings.
(2) STRC Slash 4x4 Castor Blocks, Gunmetal
(2) STRC Slash 4x4 Steering knuckles, Gunmetal
(2) MIP HD Slash 4x4 CVD's
(2) MIP 6mm outputs
(2) Traxxas Upper links (Camber)
(2) Traxxas Steering links (Toe in/out)
(2) RPM Nitro Stampede Rear arms
(2) Traxxas XXL Big Bore shocks w/ Black springs
(1) bottle 40 wt shock oil
(1) bottle 100 wt shock oil
(1) Cut in half Slash 4x4 including shock tower, skid, diff housing, ring and pinion, hinge pins, hardware, etc.
(1) STRC Aluminum Slash 4x4 steering upgrade
(1) JR 9100T steering servo w/ aluminum arm
(1) sheet of Black Styrene
(1) Hitec 645mg Winch servo + bobbin spool
(1) Complete Summit TRansmission w/ spur gear
(2) MIP C-drive AX10 drivelines
(2) MIP 6mm outputs for above
(2) Tekin RS 10.5 Brushless System
(1) Tube of Silicone sealant
(1) J Concepts Bajr Body for a Slash
(2) sheets of clear lexan
(1) RPM 6 LED Lightbar
(1) 6 LED light harness
(2) Axial rear-view mirrors from scale detail tree
(2) CAstle BEC's
(1) Futaba 3003 Shift servo
(1) 3 Racing suspension Winch and control board
(2-3) Stick of 3/16 DOM steel tube
(1) stick of 1/8 solid rod
(2) Hot Racing AX10 shocks
(1) Kimborough servo saver
(1) complete Axial Axle
(2) Aluminum Axial lockouts
(2) Axial straight axles
(2) Hot Racing AX10 wideners
(1) New Era AX10 4 link mount
(1) brass pulley
(20) zip ties (+/-)
(10) bags of Traxxas 3mm hardware
(5) bags of 3mm nuts, lock and regular
(4) sticks of 1/4 .049 wall tubing for links
(2) sticks of 8/32 all thread for links
(1) Octura Teflon sleeving for links
(1) Can of Tamiya Metallic Red
(1) Can of TAmiya Gun Metal
(many) Decals
(1) Parsec Rally Interior
(1) sheet of 16 guage steel
(1) Maxamp 4200 11.1v Lipo
(1) Bit of screen soor material
(1) 32 pitch pinion
(1) Stick of 1/8 flat steel strip
I think that's it?
LOL.
