4PK Wiring Diagram for Ultimate Setup - This is hyperlinked to the first post for ease of looking.
after looking at all your info, im wondering how to hook up the cutting brake when it comes avalible, any info?
snip
Off the top of my head, I think all you'll need to do is pick a DT button, assign the 4th channel to it. Set the increment to adjust to 100, basically a 3 position switch. Adjust the endpoints and you're set![]()
Nice! Should clear a lot of things up for people "thumbsup"
There isn't anything in channel 4 though. Whatcha talkin bout Willis?
The BEC will need to be wired directly to the servos. From there, you will plug in your cutting brake servo into channel 4. Depending on if the cutting brakes will have 3 or 5 positions you will program one of the DT buttons to channel 4 with either a step value of 100 or 50. As soon as the cutting brakes are available I will have the setup posted "thumbsup"
Yup, basically the same thing. 8)
Ok, I'm done making retarded posts now, lol.
I don't believe you for a second.
Hey now
See there I go again. Ok, no more hijacking. See you in a few weeks in OK!
Ummmmm dude......we have like less than 2 weeks..... You really are on a roll tonight.
I'm trying to buy the new Futaba RX that is thin..Seen it listed before...This
thread is so long its almost impossible to find anything...I need to be point in the
right direction...Thanks.
ty.
Always do....no one ships faster the RPPR614FF is the model
http://www.amainhobbies.com/product...614FF-24Ghz-FASST-4-Channel-Receiver-4PK-4PKS
Id try supporting RCC vendors first ;-)
EDIT: RPPhobby has them.
Had time for this yet?While thinking about it, it may not be possible with this particular setup. This would be due to only one channel actually being mixed normally. The second mix only comes on when you want to cancel out the actions of channel 2.
So if you want to mix the front motor you may have to revert to my old setup.
I still do not suggest adding the front motor mixing. It just isn't something that is going to be useful on course in a timely manor.
I will still grab my radio as soon as I have a spare minute and check it out.
