4PK Setups, Tips, Tricks and Help
You need to change what mix your DT button is controlling. If you are doing PM1b you need to do PM2B or vice versa.
Cool, I'll check it out when I get home. Thanks Harley.
By changing the mix it controls will change the dig locations though? Putting front dig on the wheel bezel and rear on the pistol grip?
Easy Peasy! Thanks Harley, time to get to soldering so I can use this beast.
I must have missed changing the mix the button controlled when I did the bbeaty workaround.
I am self admittedly not the brightest crayon in the box and a former speky guy. Much0 to learn.
As always your knowledge and input is much appreciated. "thumbsup"
Edit: Rig is back together, wish I had made the switch sooner, it is friggin awesome!
3pks/duel esc setup
Harley,
I am trying to set up my 3pks for duel esc. Followed the video. When I get to program mix 1 and set the mode to active the function will not turn on. Says active but in parentheses says off and will not turn on. Program mix 2 sets up fine. Says active and switches to on. I think because of this I am unable to get rear dig. Front dig works great. Any suggestions.
Never mind,Got it
Thanks,
Neil
Harley, Whoodie, bbeaty and everyone else who has contributed knowledge to this thread, I can not thank you enough.
The radio kicks much ass! I managed to pull off a win my first time out with it on Sunday. The switch from dx3r to 4pks is much smoother than I anticipated.
I just have to adjust to not turning off both mixes at the same time :lmao:It did cost me a course finish. I went to Sundays comp with 3 new sets of tire\foam combos and a new radio, I had only planned on testing and tuning in a comp environment. thing went better than planned. "thumbsup"
What are the least expensive RX's that work with the 4pks? I need to pick up a few extra for other toys that are with out RX now, 3ch would be fine if they work.
Harley,
Thanks for your help in setting up my 3pks with proportional dig. Works flawlessly. One other question, will this setup work with a straight 3pk? I have a friend with a 3pk that would love to run duel esc's with proportional dig.
Thanks,
Neil
I tried the bbeaty workaround on my 4pks but when i hit servo view i just get the bar graphs. I think i must be missing something. Yes?? No?? This radio kicks a$$ by the way!!! Best money i ever spent"thumbsup""thumbsup"
If you do his work around you need to change the switches that control the mixes as well. I don't use the work around so I don't exactly know.
Had a brain fade and didn't change to servo view in system set up.Works mint!!! Thanks for your quick reply and thanks to bbeaty for this little tip.
