LOSI CRAWLER SETUP
This is simple and strait forward, just want to give you guys a quick reference.
Go to a clean model and name it for reference first.
This is what your home screen will look like.
Next you need to decide what switch you want to use for your dig. I am programming this using DT2 because I am guessing many of you will use this one.
Go to the DIAL menu:
Set DT2 (or whatever dial you choose) to read: CH3 100 / NOR
I chose to also clear the rest of the settings on the screen so I can't screw anything up while driving, this is just personal preference.
This will give you a standard 3 position switch on the 3rd channel. Pretty simple "thumbsup"
Now to adjust your end point adjustments (EPA) so that your steering servo is only moving the proper amount do the following:
Go to your EPA menu:
With the rig in the air (tires not touching the ground) adjust the ST values until you get the amount of steering you want. I suggest going to full lock and then dialing it back a fair amount since this truck seems to extremely weak CVD's:
These values are just for example, actual values will depend on servo and servo horn length you are using.
Now repeat this if you want to setup a dig servo:
With the rig in the air (tires not touching the ground) add a small amount of throttle and adjust the 3rd channel EPA's until the dig engages and disengages with full engagement:
Any questions just let me know, and don't blame me on your steering end points breaking your CVD's ;-)
