edan
First I would like to state that I am new to this hobby and I am just trying to educate myself by asking this question. Second, I am not trying to challenge anyone….just learn what the correct way to run/modify my crawlers is.
I currently have the following:
Axial Honcho (AE-2)
Axial Rubicon (AE-5)
The only modifications to the electrics that I would like to make is that I would like to change both to a HiTec 7955 steering servo.
I see on the forum that a BEC is highly recommended. HiTec also recomends a Castle Creations 10 amp BEC for this servo.
The problem I am having is that Axial states that a BEC is not needed for these two crawlers. I have spoken with two different tech's from Axial and they both state the same, that this servo will work fine as the rest of the electronics will handle this without a problem.
So my question is has anyone just put a 7955 servo into one of the above crawlers? If so, have you had any problems?
Even with my evac system for my soldering station, I still have a bad reaction when I solder due to my asthma, so I am hoping to skip this if possible. (soldering in the BEC that is)
Thanks in advance
Axial Honcho (AE-2)
Thanks in advance
