Axial AX-10 Picture archive - No talking
Nothing special but bought BRAND NEW still in the box about a month ago so finally got it up and running so here it is with the Silverado HD body for a stampede as the wheelbase was almost perfect
Awaiting my Voodoo Gold Dots and Axial Rockster rims as my CI DD foams came saturday
This is the look for 2013, I have lowered the body and mounted the electronics on the front axle since the picture was taken. The chassie is Gatekeeper GC3A:
This is my Scorpion as it sat back in it's comp'ing days,
Add in a Jones'n Poison Dart chassis, some custom Krawler Konceptz skins, Eyeball Engineering D-mounts, and the XR mod on the front axle.......
[FONT=&quot]My AX-10 (more or less) tuber.
- Custom 3/16" welded steel tube chassis
- Traxxas VXL-3m speed control and Velineon 380 motor
- Savox SA-1283SG Super Torque Steel Gear Servo[/FONT]
[FONT=&quot]- AX-10 tranny w/steel gears
- AX-10 Axles
- Rear axle lockouts
- Carbon Fiber skidplate
- Aluminum suspension links[/FONT]
- Aluminum Steering tie rod
- 4-Link front and rear
- 1.9 Axial beadlocks
- Axial 1.9 Trepador tires
crawler_005 by jamipellegrino1, on Flickr
crawler_004 by jamipellegrino1, on Flickr
crawler_001 by jamipellegrino1, on Flickr
crawler_006 by jamipellegrino1, on Flickr
here are some pics from last week at a dam I like to crawl at,the truck up front is my friends and started out as a creeper...the green truck in the back started life as an ax10 and is now an almost scratch built honcho,custom cut frame rails and a bunch of ax10 parts
hammer tires on stock wheels,savox frame mount servo,goat 3s esc with a losi 17.5 motor from when I raced sct,modded losi shocks on white traxxas springs.
this winter im chopping of rear end off and back halfing the truck and possibly an exo cage or something.
Here's my newly completed Bender Customs SWX.
AX10 donor/SWX chassis/Black links with stripped and polished donor alloy.
Axial BTA steering
Axial alloy C-hubs
Axial HD lockers
Axial HD CVD's
Axial 12mm alloy locking hex's
SWX 4 link plate rear + 3mm 6082 handmade front plate
Mayhem engineering single Phatty's
Junfac Carbon steel driveshafts
Vanquish products rear lockouts
Losi CC 100mm shocks R35+F45w oil,6mm external travel limiting
Losi R white + F white springs
HB sedonas/white + Panther memory foams
Fireball 60t motor-tweaked
Mtronics Tio Rock C ESC
Henge 6V-5A BEC
Blue Bird BLS-31A brushless,digital,HV,titainium geared,full alloy case
1300MAh 3s Flightmax cells
Kamtec split screen Baja Beetle shell finished in sapphire flip with pearl ivory and chrome.
Trick Bits small body mounts
Center skid height-2 9/16"
Track width front -10 3/4"
Track width rear-10 3/4"
Wheelbase-12 3/8"
Front wheel weight-inc tyres/inserts-
Rear wheel weight-inc tyres/inserts-
All up weight-RTR-
Rewired and electrics lowered.
Grip Roll
Built in 2008 ..then converted to a tcs gopher
18.5 novak goat 2s
1230 savox
Vanquish dhcomp rims
A re-built 2nd hand crawler. Begun in 2010. Now:
Austrian RollerCoaster delrin chassis by Gerry / MIP shafts / felsenfest spools / Axial CVD's / VP high clearance knuckles / custom bta steering / Bluebird BMS 630 MG, alloy mounts, Robitronic arm / HH 35T handwound / CC SV2 / Rockamp hiQ 60 C 1200 or 40 C 800 mAh / Hardline shell /some gold anodized parts / VP DH Pro Comp narrowed to 0.8" front / 0.7" delrin beadlocks by Martin Währisch rear / HB Rover white / Proline 2-Stage Memoryfoams front and serial rear foams
How it looked 2 years ago:
