Brazing
hey fellas, couple questions. would you be able to use a high-watt soldering iron to do this? second, if so where would be the best place to get one, and last, where do you get silver solder from?
Safty-silv 56 melts @ 1145 F/618 C. So you will need to heat the parent metal to this temp. Mapp gas torch with a 'swirl' tip is rated at 3600 F/1980 C. A good quality 80W soldering iron will get you about 850 F.
Your best bet would be to find a local welding supply shop, they usually stock all you need for brazing.
ok so i went to home depot and bought the oxy/mapp gas torch to practice braizing. any one else use this setup? im starting to get the hang of it, but by the time i get going, the oxygen runs out. i burn through 4 cans of O2 before i finish a can a of mapp. is that normal?
Yup, same problem after about a dozen oxy cans, I got pissed and bought the Bernzomatic TS 4000 that uses only Mapp gas with a swirl tip, works ok for me so far, although it takes a little longer to melt the brazing wire.
Would something like this work for the torch head?
i was using a regular can attached torch but it was making my aluminum table top bow. took too long to heat up.
Make sure it's made for MAPP gas. There are several different types of heads. Assuming it is, yes, that will work, although I much prefer mine with the autoignitor button on it. Complete pain in the ass to have to constantly light your torch when you do as much brazing as I do "thumbsup"
I found out that usuing the wifes extra cookie trays help out from not getting the table to hot during the process.
i use a piece of 12x4 1/4 thick piece of steel, Home Depot has them for a couple bucks. if you get a couple welder magnets they help hold the pieces stable and up from the plate.
