cheap WK based build
Thanks for the info I'm gonna pick me up some like that, I figured it'll be about 1/7th to 1/8th scale so I definitely need something bigger tires to match and those look sweet.
That's a killer build, I need to post up a pic off my last Wheely king I built... I loved my Wheely king and miss it dearly :) it was a ax10 killer back in the shafty days:)
are you going to pick another one up? main reason I got it is because they're cheap reliable and solid axle so good for a scratch built budget truck.
[/IMG]got the motor and trans mounted still need bottom bracing
securedownload
Ok so it's been awhile since my last update, been dirtbiking alot then my bikes crank and top end took a dump. So back to my cheaper hobby. I wanted a more scale looking chassis so this is my take, and this is new to me so bare with me. I know brake line and brazing with map is the best way to go about it but I have to wait til I can afford the map setup, so I'm trying brass and silver solder for just spits and wiggles. I've seen people use brass on a couple builds, I know the cons but this is only a project till then.
securedownload
securedownload
