Heat shorts are just that....a short that happens with heat. Typically its the insulation of the wire gets hot enough in a spot where the wires can then touch....short happens. Arm cools down, insulation hardens stopping the short. Run it again, and it repeats. They are nearly impossible to find when you rip the armature apart as it often pulls the wire apart and you can't tell if it was epoxy or the shorted area...sometimes depending where the short is, the motor will still run, just badly and really hot....which often leads to a full meltdown.
A stalled arm is something that I coined a while back as we got into crawling, we never really saw these in racing. It for all intents is a shorted armature as well, but there is no direct thing to point a finger at let alone knowing 100% what causes it, my guess excessive amp draw, but not all stalled arms were exposed to excessive amp draw.
Basically, its when the arm needs to a push to go, and works fine until you stop typically. Then needs a push to go. It kinda mimicks a hung brush, which makes it a pain in the ass to spot sometimes, as a hung brush often just needs a quick comm cut and brushes, problem solved. A stalled armature there is no fix, just need a new arm. Problem is, a rebuild often shows NO problems on the bench, even the dyno shows no issues....but as soon as its back in the truck the ugly problem rears its head again.
Its to the point, when a motor comes in for a rebuild....if in any way I suspect a stalled arm from the symptoms, I run a whole extra set of tests. Lately my meters have been pretty good at picking them up, but not always...the big issue still is customers not telling me known problems, so I don't always catch them during a rebuild....then I end up the asshole when I send it back thinking its fixed.
Later EddieO
