Ok, so I'm trying to figure out the install on this, I also have the dhawk spacer. With 2 shims and tightening the unit together the gears get really notch you and hard to turn, I remove 1 shim and it is a bit better thigh the screws to tighten the boy together are only snug roughly. My question is anyone shimming side to side at all? Seems like a huge pita to fit, take it all apart, then take the diff apart, add a shim, and the reassemble to test fit again with fingers crossed....
Anyway, are there shims that fit that will go over the drive cups to keep from going through all of this?
And biggest question is how smooth and how easy should the driveshaft be to turn for optimal fit? I would think that it should pin pretty easily and be pretty smooth but I can only get it this way by leaving the case screws loose, like barely any pressure to tighten them loose.
And those damn dropper top deals on the diff fluid bottles know just when to pop the f?$& off, looked like I gave a hand job the a yak....
