I recently picked up a Jeep Hurricane that is being built on another thread. It got me thinking about running 2 motors. I have always been boggled that you can either have a rig that is slow and controlled or one that has great bump speed but not both. Big blocks are nice but aren't completely solving the problem. So here is my solution.
First off I made a mock up bracket out of carbon fiber. The actual one will be in aluminum.
As you can see the 2nd motor fits on top of the trany in an open area. No mods to the case at all.
I will be changing the Turbo motor pinion to a metal one soon. This was just for mock up.
So I had to make a way to control it. I am using a Mamba Micro ESC, a 3 channel TQ3 2.4ghz radio and receiver, and as you can see here a 3rd channel servo on a micro switch to send power to either the main motor or the turbo motor. I mounted the servo to the rear axle to gain space inside the rig for other electronics.
I had it all running but did not take video yet. I am still working out the chassis and body. The good news is that it WORKS!!! You can crawl slow and strong and at any moment (even at full throttle) hit the switch and the turbo motor kicks in instantly. The heat on the motors is a little more than normal but not bad at all. The extra drag of the second motor not under power is very minor. I ran a pack through it and found that I was very happy with the results.
This could also be two motors running at the same time but the battery would have to be huge. I tried that a long time ago on a dual trany/motor setup and it sucked down the 400mah battery in 5 minutes. This one ran for almost 15 minutes with constant switching to the turbo motor.
All I can say is that if you have the room for all the electronics this is a cool mod. I will post up a video soon.
