I know how bad AZ, can get... I've had to do some training out in Yuma several times... I despise that place lol Nothing like living in tents out in the desert for a month and a half and no A/C when its 120+!!!
Got chased by this guy too
Anyways back to the subject at hand lol
I know its possible, probably a little difficult, but it would be interesting if you come up with a wiring schematic where at low trigger input (from your radio) the slower motor was running then once you were close to full throttle a relay switched over to the faster motor. So it was all automatic and you didn't have to tie up another channel on your radio. Or stop and flip a switch..
In theory you could probably do it with a relay and figure out what the power output curve is and then wire it up so lets say the lower 75% the slower motor would be running then once the wattage hits the last 25% ( or close to full throttle) the relay kicks over to the faster motor now giving you an instant transition to more wheel speed...
Or... If i remember it right you could have the wiring set up so it all acts like filters.. I could be wrong, its been a while, but lets say your power curve goes 1-10 watts. Now your slower motor is wired up so it will only run from 1 watt all the way to 7 watts. Then the faster motor will only operate between the 7 and 10 watt mark... This way would probably be Alot more difficult and use a lot of tweaking getting that transition smooth and ensuring there isn't a dead spot there or a moment where both motors are on at the same time...
One of the down sides i could see happening to this is, as the battery dies the voltage drops thus dropping the wattage now making the curve like 1-8... And depending upon how its wired up, once the battery is low you could possibly not be able to hit that top 25% to run the faster motor...
So again, supplying a little more food for thought... Lol
