Brake Weight
For those that might care, the RGT body is a drop on fit. Body post holes and all. Looks better IMO than the truggy body to me.
Dose it come in clear?
Sent from my SM-N960U using Tapatalk
Probably not a direct drop on. You’ll have to adjust the wheelbase to fit it.
Hmm, interesting and different, but also huge and wonky. The mini Gelande V2 transmission swap seems like a far better option.
Sent from my LGMP450 using Tapatalk
I finally got my axles from China for the WPL models to use on my Barrage. They are surprisingly made of steel and not aluminum. Found that out when I cut them down to fit the Barrage chassis. So far so good on the trail run. I’m sure they’ll last longer than the U joint chunking OEM shafts.
Axles?? or did you mean driveshafts?I finally got my axles from China for the WPL models to use on my Barrage. They are surprisingly made of steel and not aluminum. Found that out when I cut them down to fit the Barrage chassis. So far so good on the trail run. I’m sure they’ll last longer than the U joint chunking OEM shafts.
Need pics.
