Abavuso
It'll work. 8)
That's golden!!! exactly what will beaf up the drive line!!!
It'll work. 8)
The only way to provide a strong enough boss for the CVD stubs was to go with the 8mm ID bearing.Looks good!
So, what did that take to get them to that point? Think that will work with the stock tubes or did you have to use the max tubes for the bigger bearings?
Thanks, man!
Is yours still apart? I'm having a ton of fun with mine... and haven't charged a battery for ages.
Guys, how much would almost 60* of steering be worth?
It could happen... I think. When building precision machinery, I always do something uncommon here: Support twin bearings in the center as well as the outer race. It means you have to fit a spacer (between the center races) of equal (or better) tolerances as the bearing's itself.
This not only spreads side loads (thrust) between both (a typical knuckle floats those loads to one or the other), but positively locates the born part, if it has a boss (pin, collar, or nut) incorporated. Smoother, stronger, and more precise.
A double universal joint can go smoothly to about 60*... IF it is supported and located rigidly and precisely at both ends. It would be labor intense, but it can be done.
Could it be worth it?
Got the dimensions of the Axial hex tube ends?
You're right, J. I was thinking about those on A's rig. Venom.
Axial uses both round and splined, correct?
Thanks.
If you can make room for an 8 x 12 x 4 bearing, I can cut you shafts I'll cheerfully guarantee for life. We could set XR 45* CV joints in with no problem.
