Losikid, Just suggestion, make some video's like Harley did with Futaba radio's.
I bet that will make it alot easier on everyone.
Sorry if this has been covered but I dont wanna go threw all these pages.
The only trouble Im having is when going from forward straight into reverse, my 3rd channel (rear esc) doesnt go into reverse, only the front. It goes into rev once you center and push rev again though...
What ESC??Sorry if this has been covered but I dont wanna go threw all these pages.
What ESC??
Most have options of:
-No reverse
-Reverse with a pause at neutral (what you have) AKA, "Double pump reverse"
-Immediate reverse (what you want in a crawler)
Check your ESC settings, if you don't have a manual, go the the mfr website.8)
Dang, benoj typed less & beat me.....:lmao::lmao:8)
i would check you rear esc settings as it sounds like delayed reverse is on. just the radio mixing shouldnt cause that.
No problem, glad we could help out!8)8)Oh geeze, I can't believe I missed that, LOL. That was the problem, the ESC was on brake and not crawler brake. Thanks guys.
If it ran in reverse, I doubt it's something inside the motor.After binding my 6ch RX I powered up the TX and then the truck. Immediately it started driving in reverse and the engine was glowing red. Any ideas before I start tearing the truck apart? I made several adjustments/modifications to the suspension etc. while I was hacking away at the radio. If it's nothing to do with the electrical side of things all I can think of is that some debris may have fallen into the windings.
"Glowing red" motor is really bad......:shock::shock:
Did you calibrate the ESC to the RX? That could explain the running in reverse when powered up.
Hope you didn't fry the motor.![]()
When I first started using the fs gt3b with the original 3ch rx I had to adjust the throttle trim heavily one way to prevent it from running as soon as it was powered up. Can you explain a little more about this calibration that you speak of? Also, I had run it in the mud once and got the same smoking/glowing scenario before. After cleaning the engine no more smoke, no more glow. That's what made me think something had possibly gotten into the motor to cause this again.
In general, yeah, sorta. As mentioned, it differs between ESC's.calibrating your ESC to your radio is a little different with each ESC.
basically you put your ESC into calibrate mode. hold full throttle till it prompts you. then neutral till it prompts you. then full brake/reverse till it prompts the last time and tells you its done.
Ordered my mod. What is a good soldering iron to do this with?
Broke the board in two, and i get :
error : Cannot communicate with the board.
Wrong board selection or check board power supply or check that a previous session is closed.
Error : < PROGRAM MEMORY programming failed."
Yes i did, i don't usually post questions if i haven't searched before;-), i have done that procedure and no go, get the same message.Have you by chance read the 2nd post on this thread? I think i linked to the post where i explain what todo if you so happen break the board in two (which i don't recommend)
