53 willys
Still running 350 hubs at all 4 corners.
what rings did you get on there?
Mine rub(slightly)with this set-up. Hmmm wondering where the difference may be.I fit .400 worth total, 1-300 and 1-100.
Yeah the SSZs. The shim job may do the trick! I may horse trade the SSZs for some V6s or something:mrgreen:Running SSZ's? Mine are extremely close and the slop in the stub will likely cause some rubbing but not enough for me to be concerned. Like I was saying, I plan on shimming the stubs to try and take up that slack.
like I'm rolling 20's on a Civic
I have the exact same knuckle weight setup and it comes in at
4.05oz. "thumbsup"
I'm still running 1oz. Extra in each wheel to keep my weight exactly where it was previously.
what do you know about a fine tuned rig....!....:ror:Not sure how those wheels stack up to the slw's as far as track width, but I have run all widths and by far the 475's in front and 600's rear have done the absolute most for overall stability and performance. Also try a few more ounces in the fronts...I know lightweight is the trend but think along the lines of the fully slugged dirty harrys and you will be on to something."thumbsup"
There is much more slop in the front stubs then I am ok with. I am going to start by shimming the bearings. We'll see how that goes when I get some shims.
Maybe a buddy can hook you up with some LCC pinion shims. I used 4 per side, between the hex pin and the bearing, to take out the majority of the slop. Nice fit around the stub's diameter, and tight enough so they ride up against the inner race of the outer knuckle bearing.
These for sale yet harley?
They have not arrived yet as far as I know. They should be stateside and to distributors in about a month.
