Servo page is here. Waiting for the fancy photo, it looks just like the HV500 plus an extra pigtail. It uses the same gears as the HV500. I redesigned the drive motor and changed the electronics for higher voltage use and cooler running.
SHV500 Servo - Servos - Electronics & Wiring
The rundown:
The BLS SHV500 servo is designed for R/C Rock Crawlers, but at home in any vehicle. It is powered directly from a 3s lipo, eliminating the need for an external BEC! Clean up your wiring, gain space in a tight rig, and enjoy near silent performance with the upgraded brushless motor and circuitry.
FEATURES:
Water-Resistant Alloy Case
O-Ring Seals
All Metal Gears
Brushless Super High Voltage motor
Upgraded N38EH 200c rated magnets
24cm servo lead
24cm 12v power lead with JST plug
3s Lipo compatible (16v max)
1 Year Warranty
SPECIFICATIONS:
Weight: 73g
Dimensions: 41x20x40mm
Spline: 25 tooth (Futaba type) M3 threaded
Torque @ 11.1v: 32.4 kg/cm (450 oz/inch)
Speed @ 11.1v: 0.10 sec
Torque @ 14v: 37.5 kg/cm (520 oz/inch)
Speed @ 14v: 0.08 sec
I engineered the motor to have about the same output as the 8.4v version, but the speed increased quite a bit. We have been running our prototypes for about 6 months now. It's weird not having a BEC on the rig!
