I had the Savox SA-1230SG servo and Traxxas metal servo horn waiting to be installed to replace my dead, stock servo. I was awaiting delivery of the Yeah Racing aluminum servo mount which arrived on Monday. I was tipped off by this Yeah Racing plate by LSXGMC. On his thread he mentioned that this plate has obround holes in one side to accommodate all servo sizes. If you use the stock servo plate with a Savox servo you have to modify the tabs on the servo. I didn't want to do this since the tabs are plastic. The Yeah Racing plate was the perfect solution. It is a very nice piece and does exactly what it was designed to do. But it was a PITA to install. The servo plate is in between the frame rails so you have to remove the front bumper mount, front plate and then loosen up the frame screws so you can spread it apart. I missed the screw that mounts that Panhard bar to the frame also goes through the skid plate.
Under all this stuff you will find the servo mounting plate.
Here's the bottom view. You can see the servo mounted to the stock, plastic mounting plate. That's where the Yeah Racing aluminum piece needs to go.
Here the servo and all of the stuff in the way of the plate has been removed. The frame screws have been loosened so I can spread the rails apart.
I didn't have much patience to start when I decided to tackle this and it only got worse as I went. The servo is in, but I didn't even remember to take photos.
Once the servo was in I had to remove the two screws holding the shocks and lower links onto the axle. You have to drop the axle in order to install the servo horn on the servo.
The servo is strong though. Now I have to figure out how to adjust end points so I don't kill the servo. Is it possible to adjust EPA on the stock transmitter?
