I use only 4 settings on the ESC as there really the only things that apply to us crawlers.
Voltage Cutoff
Drag Brake
Reverse Mode
Reverse Strength
Voltage Cutoff - applies to the Lipo or Non-Lipo battery that your using. I personally use a 3 for a 3S lipo setting.
Drag Brake - varies greatly. Motor, rig weight, tires, terrain, outside temp, rock temp, etc....all effect drag brake. Here is what I've found. When I go to a comp I test the rock with the rig setup I'll be using for the day. If it's colder outside the traction changes a lot so drag brake needs to be modified. What I like is when the rig moves slowly under it own weight on a steep incline. How steep depends on the courses. I don't use my drag brake to stop the rig but to control the decent, so tire traction changes this from comp to comp. In Moab for example I used a 28 with my berg when I usually have it set to 31. This was due to the lack of traction from the rocks sluffing and it cooling down.
Reverse Mode - I use instant reverse, however you need to be careful with this. If your heading downhill and you need to reverse you can easily flip yourself. Or say for example your on the flats and your about to hit a gate so your hit reverse only to backup into another gate. This leads me into Reverse Strength.
Reverse Strength - I have this set to 65%. So that when I mash the reverse I don't shoot off at mach 1. This setting depends on the motor wind your using. For example I use 35x1 hopped up so I don't have my reverse strength set too high.
Other settings that you see in to the Hot Wire may not be settable on the FX-R. Some settings are for the FX-R and therefor zero out if you try to use them.
On the Hot Wire you are exactly correct when you say the values are set from 1-100 where as the values in the field are set to 1-10.
I need to get a Hot Wire review put together and will work on this over the weekend ;-) I will say this, for those of your who love your FX-R as is using the field settings.....Your only using a fraction of it's potential. The Hot Wire opens up a ton of more fine tunning and I can't imagine using a Tekin ESC without the Hot Wire. Having the ability to fine tune like this is so important and I use one at every comp. "thumbsup"
I hope this helps.
8)
