Sounds good to me, man! What battery are you planning on running?
my settings are at were they should be from reading this thread but for some reason i have a very slow reverse???? what do i do?
i have it set to
40
100
off
1
f/r
3
and everything is set to 100% on my dx3r and it was fine till i tried to change my drag in hotwire. i pluged it back in and now i have a supppper slow reverse
Is this available yet?We are adding the basic 6 throttle profiles that are in the Fx to the FxR in the hotwire soon. We will be adding the custom throttle profiles where you get to make a curve as well in the future.
Your absolutly correct. They need an external BEC especially if your running two servos. You just can't pack that powerfull of enough BEC in such a tiny package ;-)
8)
Yep...the more voltage you put into the ESC, the less power goes to your servos. You will need a BEC unit to cure that problem (CCBEC or Novak 5A-6V BEC).
