Dbdynsty25
Tires are 105mm (35mm wide).
Much thanks!
Anyone have any idea when these things are supposed to be back in stock? Saw others waiting since February, not sure if they keep the supply coming or if we’re all STILL waiting. It’s killing me!
RPP has both colors of the RTR available
https://www.rpphobby.com/SearchResults.asp?Search=kyosho+rampage+pro
or are you after the kit?
On mine the limiters are still there, softer tires than original, static at full compression there's about half a cm left before bottoming the chassis ... no need to go let the shock compress further, it'll already hit the ground when landing at speed with the tires flexing.
With kit's aluminum shock, there's no fear of blowing them. With RTR's plastic shocks, I guess they may pop-off on landing once in a while though.
Plastic gears, and none metal available.
Plastic gears are fine, it's not supposed to be powered like a Slash.
