Which springs are you running?
Not 100% sure Jato as these are on a 2nd hand new-to-me built rig but looks like the stock springs to me.
I've owned a few sets. Three? on TRX-4s and one set of takeoffs. I remember one set had some leaks but the others were solid.Get Traxxas GTS take-off shocks on eBay. You can get all 4 for under $60. I'd take those over any of the others you mentioned. Priceys look cool and are scale, but I can't see them performing well and the feedback on the FB groups seems to back that up. Proline scale shocks seem to be notoriously leaky. That's a shame since their big bore monster truck shocks are awesome. The other brands are just unproven. Ottsix is owned by a clown so there's that too.
I do have a box full of different rates in case needed. I don't worry about brand, just the spring rate needed. Which is why it's annoying that vp don't know or won't tell me the rates in their spring kit.
Yes, coatings matter! TiN coatings help a ton to remove "stiction" in shocks. Chrome is more durable but has a higher stiction rating.I think the coating matters when the pistons are tighter against the shock bodies. I believe a lot of RC shocks are designed with a lot of slop between the piston and body which allows for a ton of "blow by", but that is how they seem to control damping rather than by just using holes in the pistons.
Having been a shock and suspension engineer dealing with world championship level racing in the past, I can totally see this. Just trying not to be a kook myself with a fun hobby, especially when it doesn't really matter.In the Racing scene, I've seen people go as far as weighing out pistons, measuring for roundness, and validating diameters with micrometers. Some of the folks are really out there in the weeds of wanting everything as consistent as possible.
I'm def not an engineer, that said with all of my experience in the auto (racing, 4x4) and moto world, I've learned more than a fair share of things.Having been a shock and suspension engineer dealing with world championship level racing in the past, I can totally see this. Just trying not to be a kook myself with a fun hobby, especially when it doesn't really matter.
Sometimes it's hard to resist.
That's awesome!Having been a shock and suspension engineer dealing with world championship level racing in the past, I can totally see this. Just trying not to be a kook myself with a fun hobby, especially when it doesn't really matter.
Yeah, I've thought about making something like that rate tester for the kitchen scale from some lumber scraps, a ruler and some nuts and bolts. Couldn't justify buying it though.There are RC spring rate testers like this one from G-Force:
This gets pretty close to or better than engineers in many cases....with all of my experience in the auto (racing, 4x4) and moto world, I've learned more than a fair share of things.
My Fordyce came with at least one stripped bleeder screw threads so that's awesome.The bleeder screws are very easy to over tighten, I’ve heard CA glue on the threads will help once that happens, but not sure what happens when you need to remove them again.
My suggestion would be to look into dlux dravtechs, element enduro shocks, or trx4 shocks for good performance and virtually no leakage. Just be aware the bigger bore shocks can cause interference with the shock mounts.
I ran into the issue of the GTS shocks interfering with the VS4-10 shock mounts last night. The preload adjuster won't turn. I did find out the preload collar from the Vanquish S8E shocks threads right into the Traxxas bodies so hopefully that remedies this problem for me.
Auto bleeders. It's a "feature". LolMy Fordyce came with at least one stripped bleeder screw threads so that's awesome.![]()
There's a write up on FB about how to get the shocks to stop leaking. Some people like it and others say nothing stops the shocks from leaking.Has anybody tried the X seals from the gts shocks on the S8E bodies. They are a lot less expensive and if sized correctly, could help. TRA2362 TRA8262
I've used Teflon tape before and it didn't seem to help at all. I think that was on Axial shocks with plastic caps and aluminum bodies, but I could be wrong about that. I think tolerances are everything when it comes to making a non-leaky shock.this might sound kind of crazy, but has anyone tried RTV gasket or Teflon tape on the caps to stop the leaking from that area?
