Stormin2u
Great article, I enjoyed your process. I'm running the stock shocks currently but might have to try a longer shock. ... "thumbsup"
Did you consider at any point using a 100 mm shock with only a 10 mm gain?
I know you know this but just keep an eye on the pan hard mount of those HR shock mounts. The single shear design will break.
No, but only because i had the 110’s and 120’s already sitting around from a previous endeavor. I couod easily get away with the 110’s on all 4 corners and not have to jump through hoops to do it. I think the Long Arm TRX4 shocks would work well but they are $ and have less travel than the Hot Racing 110’s i already had.
Also, i was not worried about the extended length, only about the compressed length being ~10mm longer with regards to the shock tower height. I wanted the tires to still travel up the same distance and “stuff” into the wheel wells. Really i am gaining down travel. I guess in a sense it is like running a mild droop configuration where the shock is sitting deeper in the travel.
How satisfied are you with the HR shocks any issues with holding oil or smoothness?
They are actually decent as far as oil goes and i dont get the “stiction” i get with the factory trx shocks.
My complaints are they can be finicky to match up when filling with oil, and the ends are not pivot balls so they don’t have a lot of flexibility if mounted off-axis to cope with suspension movement.
I just finished my trx4 build kit. not happy with the shocks. was looking at replacing, I have the traxxas big bore kit that i havent used,front and rear are differnt lengths, as well as some redcat everest 10 shocks - 120 mm.
you think they might work as well as your setup?
