My 1:6th Willys Jeep build (GI Joe)
I got the steering wheel servo mounted and hooked up with a Y harness
Sent from my A0001 using Tapatalk
I use 12mm buttonhead or caphead hex screws to go across the links, (15mm probably better so a little bit sticks out past the nylon locknuts)
25mm caphead or buttonhead hex screws to go across the center truss that attach the upper links
My flex was a little limited, so I removed the stock bump stops from the shocks for better flex
Shocks installed after removing the bump stops
Here is a quick video of the beginning of the build
https://youtu.be/VWKHkqiddlo[URL] Sent from my A0001 using Tapatalk
That's a lot of work to get done in a minute 38"thumbsup"
Hahaha...that's the magic of time lapse recording. LOL thanks for the thumbs up...I'm editing the first run video now...will post up soon
I had fun with it,but wasn't too pleased with the performance. It wasn't bad but I need to sort out the steering. I did more tweaks and went to 4 link front for now.
I was having problems with the links touching with the panhard and steering. I'll revisit it with the axle mod
Here I compare the difference between using 12mm and 14mm buttonhead screws. The 14mm is better as it clears across the nylock nut.
Front 4 link is done and panhard removed
Rear 4 link after the steel tubes over the threaded rod.
Trying out brazing to make my own roll bars
Here it is, finished and installed
Have you considered ar60s? I dont think you will ever get the most crisp steering with those wideners. I also think the added width would help with crawling performance and overall rig balance.
Thanks. The wideners I'm using are temporary just to get it running. I thought about them (AR60) and I'm sure performance would be better. I just wanted to keep them narrow for closer to scale appearance.
I am converting to XR10 axles and have the parts on the way and will be installed soon.
I thought abiut narrowing AR60s also as another substitute.
I have the XR10 mod on scx axles for my 1/10 scaler and the width is 9.5" outside to outside of the tires.
The AR60 axles are better suited for these Jeeps, o/o measures 11.5".
So, just to let you know, the XR mod won't give you what you want. "thumbsup"
Oh wow...thanks for the heads up.
It's a little late since I had already ordered the parts to complete the front axle. Either way, it will still be better than the stock AX10 axle. But, I will start looking into your suggestion with the AR60. Although I would want to narrow them as much as I can because I don't like them sticking out too much.
My axles are 1" wider than SCX10 axles and 1" narrower than AR60's and they work well.
I think, if you do the XR mod using wider beef toobs, the width comes out just about right.
IMG_0392 by nomadpsd, on Flickr
Right on, Nomadpsd. That's what I was thinking. Thanks for the tip and the pic.
I like your panhard front set up. How does it attach to the Axle?
