They are already out. Assembly required.
I know. Wouldn't mind piecing them together either, building is more than half the fun of this hobby Just hoping for a little nicer pricetag. Excellent for scratch builds or OG upgrade.
Do you guys have plans for some for HPI Venture based rigs?
SSD, any updates on different tube lengths/options?
Working on offset tubes now. But there isn't a lot of room to play with really.
We already releaseed an OG upgrade kit: Pro44 CMS & Titanium Link Set / V2 Conversion for SCX10
been running my diamond pros for a couple months now and i love them! however, on the front axle, the axle tubes at the short m3x5 bolts that connect the them to the diff housing have stripped. i just noticed tonight that a couple of them were backed off pretty far, so i pulled them out to reapply blue loctite and found that the threads from the axle housings came with them. not sure what caused that, but i think it should hold together for a while. i was thinking about getting lockoutless rear tubes for the rear housing before, maybe i'll pick some up now and move the rear housings to the front.
The tubes are metal.Locktite into plastic is a bad idea. It tends to soften the plastic, causing stripped screws.
I spoke with him on this a few days ago. He said yes but it would put the output on the bottom. ...
If you flipped the bevel gear, How come output pinion gear on the bottom? On my AR60 axle I just need to flip the ring gear and it is all done. Can you post me a picture? And explain me in detail? Thank you
P/S: I would like to use this Dimond pro axle on my SCX10 II with CheezBurger Transmission
To those that own the SSD diamonds, how is the plastic center section holding up to abrasive wear?
Thanks
D 8)
Got one for the 12.3 wheelbase too?
EDIT: What wheelbase do i end up with on this kit?
Says its for 305 wheelbase, so im kinda confused if the wheelbase will be 12 or 12.3. Since all scx2 are 12.3 and all.
