got mine the other day for the 2010 berg build what kind of glue did you use to glue them together
What color is your glue joint?
If it is white, it was a foam specific aerosol / spray adhesive. All V1 and V2 foams used this glue and it is not being used anymore. I have had two reports about that glue failing at the glue joint
If it is yellow, that is the new glue. It is a brush on, foam specific glue and suppose to be stronger. Since it is brush on, I can coat the very edges of each foam to insure a better joint. I could not do that with the aerosol / spray glue. This new glue, along with new V3 inner foam, is why the cost was increased on the foams. The glue and inner foam is more expensive and better quality. Priority Shipping is also now standard on all orders. It's faster shipping and provides the boxes used for the product. Every foam is hand glued by me, as well as shipped and packaged by me. It works out good because I can be the quality control person as well :lol:.
If anybody has a quality issue or failure, please contact me immediately. I want to make sure the foams are top quality and I am working hard to insure they are. Failures and problems need to be reported to me. I am also eager to hear / read your comments or questions.
Ok i see, i dont think i would like that lil gap between the tire and foam, let me know if you make a taller 1.9 foam and im all in! "thumbsup" Thx!
Not a problem. I will make something up just for the 4.5 tires. Thank you for your interest.
