try reversing the foams....memory stockers in the front (better foarming to rocks) and the losi stockers in the rear for better supporti was using the losis in the front and the stock mem faom in the rears. so thats why i am doing tis test. more on the test soon.
Look ma no sidewall traction! :roll:
Anyone miss the sidebite?
No, there is plenty of side bite. If there was any side wall tread you would stay hung up all the time, the rubber itself gives you all the side bite you need. Try a set, you will see.
The Northwest Traction Hybrid Reaches fill the tire a little better than the Squat, so that helps keep them from wrinkling under on sidehills. Mine work good. The outer edge foam part could be a little stiffer though, I guess.
WC, the wrinkling action is the real key to the sidebite. It stays a slick like tire in those jammed up moments so you don't drive backwards, but when you need it to bite, steer into the wall, the sidewall wrinkles, and acts like a lug, and there ya go.
and i cant imagine what there gonna be like mounted on some narrow 8 shooters:lol: should be impressive.
