So I'm doing some thinking on my way to a band concert for my sister, and I went on JoAnne's.com and found these balsa sheets. They're a good length, scaled up they are 240" by 40" which is about 20 feet by 3.33333333333333333333333333333333333333 (you get the point.....) feet.
The actual 1999 Dodge Ram 3500 is 6.4' tall and 20.3' long. So the 24"x4" should be fine. BUT (there's always a "but") the sheets are 1/16" thick and I want at least 3/4"......
These are the sheets I'm talking about- Basswood 24'' Sheet-15PK/1/16''x4'' at Joann.com
If I can find a pack of 24"x4"x3/4-1" sheets of wood I'll be golden. But 1/16 won't give me much room for detail without gluing 2-3 sheets together, which will mess with the shaping of the body's contours... So I'm annoyed quite a bit.
Grrrr......
On a another sad note- I've not found tires and wheels. Being a 99' 3500, it's gotta be a dually. But the only dually rims I've seen are crazy expensive.... The RC4WD Double Trouble "3" Aluminum Dually 1.9" Wheels are $140 without coupon and i don't have that much right now lol. Then I'd also need new tires....so I guess I'll stick with a 2500 (basically a 3500 body but without the dually rears) until I can get a new set of rims.
Grrrr......
