Winch
Ordered bunch of parts from asiatees.
Here is how I wired a winch
It is a Topcad aluminum winch for 1/10 crawler (part # 80118gu). Good looking winch with Teflon coated wire, red alu hook and manual switch.
I did not want to upgrade Axial AX-3 radio, happy with it. So I ordered Topcad remote control (# 80119) and connected it directly to 2S battery with Deans-to-JST connector.
A perfect installation spot turned out to be a front bumper mount.
Drilled bigger holes in winch plate.
You can see small bolts that hold winch on plate. Very small, could be longer.
And made holes in bumper skid to put RC4WD winch line fairlead (# Z-S0414).
Installed winch on front bumper mount. It is bolted to bumper mount and bumper itself.
Put electronics in receiver box behind rear axle. All cables are connected with extenders - no need to open receiver box each time to unplug something)) Very convenient to program ESC.
Sealed with silicon glue from Walmart (GE Silicone II). Strong stuff, had a hard time opening glued box, but easy to clean off after dried.
Finally done!
Winch is hidden under long Chevy body.
Towing hooks
No quick spots for recovery strap. To help it I installed Topcad hanging hooks (# 80131bk).
They have two small holes. I drilled 1/8" hole on the side.
Mounted through bumper mount bolts.
Going to try winch and hooks next weekend.
