Open diff option has been in testing for a couple weeks with zero failures. I should have the open diff option ready in 1-2 weeks.
If your in need of a beefier axle setup I believe Dlux Fab has it. For more info: Dlux Fab Yeti Knuckles/OFNA Shafts
Does this set up cure the weird swinging action that happens with the Yeti kit's factory Uni's?
If you mean twisting and bending, YES, the ofna setup is 1:8 buggy unis and much beefier. Are you open diff or have a locker up front?
If the front is locked, no matter what the setup is, it will always have a weird hop while turning.
If you are open diff and want to stay with a diff, hold off a couple weeks and Erik will have a diff option available "thumbsup"
Debating what to do for a knuckle option. Broke a stock knuckle and c. Already have aluminum C's. Knuckles are slim pickings now. May just go with a DLux set up, but want an open diff. Not sure if I can wait.....lol.
DLux, any hint on price of the open diff separately if I buy the spool set up now?
The RPM arms have a little bit smaller space then the stock arms. It would be easy to file a little bit off to make them fit. I'll post up when mine get here.
So far I've seen a couple bent pair of those arms.
