I guess that it seems really simple in my mind and that common sense would have said when you tightened up your wheel nut and it got tight to check it out. I have had several sets(none of which where mine) that guys didnt have to trim there hexes. I used to write fairly detailed directions for installing. I get less pms now then I used to when I included them. At some point I guess I decided to just build parts and quit hand holding. If someone can figure out how to take the axle apart and put in the new ones great if not they will pm me. Besides you dont strike me as the kind of guy that would have read the directions even if I had included them. Hell I never do. the packaging and directions all end up in the round file, and I just build.
I dont feel like going in circles over things that have already been mentioned and remedied. I said what I wanted to, you gave your reasoning and it is what it is. I got the new shafts last night and they look good. Thank you for getting them out as soon as you did. "thumbsup"
I would say approx. 20 sets where ran at nats. no issues. Nice lookin build by the way
Thanks!
Truck looks great. Are you going to put that extra cf brace out the front where the shock mounts to stiffen that extra long shock standoff?
I hadn't planned on it. I dont particularly like the look of the broken up front end when they are moved out so I'm making some stand-offs with a bell/flange on them to spread out the load and I will still be running a spreader between them since I dont need to sacrifice strength for weight savings. There are a lot of other areas where there are non structural savings and the chassis bracing is critical IMO. I'm still about 2 lbs heavier than where I would feel ok with removing structural material.
I can respect the hell out of guys like Nabil (no offence to others, he's just the only one I've seen drive in person) who can make a mostly plastic mid 4 lb car last while making it dance over the rocks. Myself on the other hand, I have not been blessed with the ability to make things last where others have been so fortunate so my only option is to build as strong as the weakest link and take away everything that isnt required.
It's amazing how things can get taken the wrong way on the internet via posts while having mixed emotions about a topic.
Being a dick and trying to lighten the situations has obviously gotten mixed up.
The difference between a dick head comment and lightening the mood is as definitive as this little emoticon right here ->
John, like myself pays someone to make the shafts and works a 40+ hour job on top of it. It makes it hard to test and eyeball every issue. Having you get 4 wrong items after having parts from the same batch be fine hurts john just as much as it aggravates you.
Having only seen your post I see very negatives posts, whether fair or valid, and John trying to get the issues fixed, even when done so he still gets ragged. I don't think I read anything good about your purchase. It sucks as a vendor to go through all this, try to get it fixed and still look relatively bad on the forums. Makes it alot easier when the customer can see both sides.
I'm not saying praise him, or think you should be pretending to be happy. Both of you got the poop end of the stick, but at the end of the day, he tried to make it right. I know first hand alot of vendors would have refunded your money or blew you off. It's happened to me.
I have only been negative on one topic. That was about the spacer that was .25mm too small to be a correct fix. I went into detail about why, if that gets lost on anyone, they must not need the fix.
In this build I decided to make note of my "luck" since from day one it has been on a downward slope and nobody wanted to believe that my luck was as bad as I say it is (see the first half of the build). That is the only reason I have been pointing out the "negatives", upon first impression.
Aside from that, I built this car around John's 300HD front axle shafts. That was the single item that made me build bergs and not try to save the XR that has taken a toll on my summer due to constant up-keep. It has been a long time in the making but I wouldnt run different shafts unless the option was no longer there.
To clarify further, I have never been anything but professional and appreciative towards John. He has done everything I have asked or expected out of a situation. I'm probably the largest pain in the ass customer he's had in a while but all I ask for is what was sold. If I get that, you'll get more of my business and everyone ends up happy, that's how it works. The luxury of the internet and online communities are two fold; the entire demographic you're seeking in one area which makes day-to-day business more streamlined, but it can also work against a business if too many people have negative experiences. In this instance, I have/had nothing against SDS Customz, I was simply documenting "my luck" over the course of this build. I was very careful to not throw anyone under the bus because I understand how things can snowball, that is why I didn't say anything about the spacer in any of his product threads, only in my build thread.
If your offered by my comments it's not my intentions. I've been viewing your build because it's very similar to mine and has turned out very nice.
Not offended, just replying in the same context. It's the internet.... I'm only here for the exchange of information.
Thank you for the compliment. It's taken a long time to think this car up and so far I'm very happy with how it has turned out. In time, I hope to be lightening mine up as much as you have lightened your up. I'm looking forward to seeing how yours comes together! "thumbsup" Two different builds, same front axle shafts, similar end results! :mrgreen:
Truck looks awesome man.... I'm super excited to see both of ours side by side to compare!
Thanks bud! Tomorrow is going to be a blast! :mrgreen:
Too much typing.... Maybe I'll be back after states, or maybe I'll disappear for good.
