Joshs4x4toyz
Did you get this figured out bud?
I have a 7px with lots of cars setup in 3 pos. Easiest way to do it....
In the menu where you select your function to operate the dig you have a "reverse" and "step" or "increment" column, change it to 100. so you will have a 3 pos switch 100-0-100. Turn endpoints all the way down or like 25. Make sure the function you chose to use as dig is at "0". get your dig in "freewheel" and bolt is up as close to centered then trim to centered as possible in freewheel (its tight). Then switch to 4wd ( I use it in forward position) slowly increase endpoints until your servo quits moving and back it off a click or two (basically engaged as much as possible without straining). Then switch to reverse or "full dig" and do the same.
Hope that helps your issue, feel free to PM me if you need anything else.
