RexRacer19
Let me 3D Print that...
First off, this will be a 1.9er. Ignore the wheels until it gets closer to being finished.
This is the first scale build for me, so I am sure that I will learn a thing or two along the way. Feel free to provide input as you see fit.
The base for this build will be a TSS Tough Truck frame. The one I am using is the 11" WB version. I have also decided to do a back half version with leafs up front and a 4-link setup in the rear.
There are some locations for spring shackles on the TSS frame, but at the time I bought it nobody had done a leaf spring truck yet. So I had to figure some things out there. I used Jugg springs and hardware on this one. The frame rails are thinner than the springs, so I needed to make some spacers for the shackles. The front (solid) part has some spacers in that are just right, but I need to find or make some round ones for the pivot in the rear.
I took a leaf out of the springs and added an extra hole to mount to TLT axles. They fit pretty well with this frame.
