Awesome. I'd definitely be interested in the twin hammers length trailing arm and matching upper for the bomber. From what I can tell the uppers need to be pretty much the same length and the trailing arms eye to eye?
Cool. Hit me up in about 2 weeks when I have more arms and we can get you rollin.
So the stock wraith rear upper links will not work in this setup? Are you familiar with Screamers build that performs the same mod? It seems on his build the stock wraith rear upper links are long enough?
It will come down to the upper link truss. Currie and Dlux trusses utilize about a 10mm longer upper link than stock. You can use a Jato end (not recommended) if your links are too short. I would just run the proper upper links though as Jatos are prone to breakage and when they break, they can often break other things. Its just best to get the correct link length. FYI, I have options on my site for both lengths.
