Worminator Crawler Comp Axle is shipping
so many questions,i also wanna see the final completed brks.
when they are in stock someone will post...and by then they will be outa stock:cry:
i'm worried about parts,if i bust a steering arm or bend a rear axle i'll be waiting for months for replacements,i hope these become readily available without seeing OUT OF STOCK everytime i click on a cool part.
so what would I need to have a rolling crawler with these I mean what transmission are the r2 series the one to use or the axial?
drive shaft?
would it have a similar AX10 wheel speed?
Also I plan to use the corefire 1000kv motor.
thanks.
After looking at this pic:
attachment.php
I realised that if this was a compound angle ~ ground clearance plus rear pointing, you could run BTA and you'd gain an extra 10° turning angle on the inside wheel without binding or huge strain on the pins
Kev
Has anyone built a rig using these? I would like to know how it crawls, what parts were used in the build, and if they have experienced any breakage.
wow man ,i can't understand why this thread is so buried?
has anybody got these under a rig yet?
i guess the upper link mount has to be incorporated into the servo plate,which won't look to scale on the rear
