I am back from Vegas now was working CES.
While I was gone the chassis arrived and just yesterday my last shipment came in. My receiver and crystal.
I have been having some trouble as a first timer with putting the build on the X-trail chassis since there are no instructions. A bit of trial and error and have had to redo things a few times.
As you will see in the following pictures it is pretty much a roller and just needs electronics.
I booboo'd and put the turnbuckles to lock out the steering on the front I realized when I went to take these pics. At least I think the curved end of the frame is meant to be the front.
Also check out that size of that receiver!
I need to shorten the wheel base even more which means I will have to use some separate screws to hold the tranny plate to the chassis so I can move the bottom links in farther.
I am also unsure as to how I am going to mount the battery plate and receiver etc. While there is the AX-10 live build thread I haven't seen a step by step for the X-trail and what has to be done differently.
I am worried that the bump stops you put on during the AX-10 build process may limit the travel too much but I dont know enough to be sure. I also feel like the shocks are a bit "stiff" and am not sure if most people stick with the 30 weight oil the ax-10 comes with and thats normal or if they are overfilled or what. Note I can press it down and all but I am not sure when it comes to flexing how much just lifting one corner should compress the suspension.
I dremeled the wheel wells where the line already was around the lip of it. The orange plastic the body is molded from shows through the paint as I havent touched it up but it makes it so the trail Dr's just fit inside with just a smidge of rubbing. Once I figure out the body mounting (nothing fancy yet I just need some basic ideas) and see how the fit will be I may mess with them some more after I sort the wheelbase issues.
Again I am sorry about the lack of updates things have been busy with work and CES and now I am writing a new blog over on mmorpg.com (my "real" job is a game designer I work on a game called Age of Conan)
