Go Back   RCCrawler Forums > Miscellaneous > 1:1 Full Size Vehicles
Thread: Bug and Guts.........
Old 07-31-2015, 08:30 PM   #1
Default Bug and Guts.........
Anybody have a good suggestion on what will work best to remove dead bugs from a vehicle quickly? I spent about 3 months running all over while my Mom was in the hospital and a few nursing and rehab places while not having the time or money to wash my car, now that she's home and I'm not blowing cash on fuel, I would like to get those critters off the front of the car.
BJoe is offline   Reply With Quote
Old 07-31-2015, 08:44 PM   #2
Default Re: Bug and Guts.........
Just take some warm water and wash it off with a small amount of soap that is how i clean my car when it gets full of bugs. Water is usually the only thing that will take the bugs off.
humve is offline   Reply With Quote
Old 07-31-2015, 09:15 PM   #3
One of those do-it-yourself car washes with the pressure washer should do it, I would think. If not, any of the local parts stores should have Bug and Tar remover, Turtle Wax use to make a real good one. And how is your Mom?
Mike Flea is offline   Reply With Quote
Old 07-31-2015, 10:08 PM   #4
There is a place just down the road that I can do that at, although I've thought about pulling the front plate and hitting it with Simple Green or Wildcat Cleaner/Degreaser to loosen things up further.
Old 08-01-2015, 01:18 PM   #5
binaryterror's Avatar
No matter what you use you'll need to rewax, the bug cleaners are strippers of the wax and bugs.
I found the Turtle Wax one works decently. Spray on a cooler not sunny day and wait. Then hose/scrub with a microfiber and all gone. The pain comes when you have to wax it when you are done, but that keeps them from coming back.
Also might be worth a detail, not the concourse show one, but any will get the bugs and get you back a clean and waxed/polished car.
binaryterror is offline   Reply With Quote
Old 08-01-2015, 02:37 PM   #6
Probably going to blast it at a coin op then hand wash it at home then, the whole car is filthy right now.
Old 08-01-2015, 02:53 PM   #7
Soak it down with something like MeanGreen or any other strong cleaner for a few minutes before hitting it with the wand at the car wash.
Brake Weight is offline   Reply With Quote
Old 08-02-2015, 06:18 PM   #8
Something interesting happened today, we had a major storm hit while I was at work (so bad it actually killed someone in another suburb ) and it actually cleaned up the car quite a bit, including the looser bugs Should make finishing the job a bit easier then
Old 08-05-2015, 05:19 PM   #9
Pledge furniture polish works great to remove bugs on my motorcycles. I just spray it on and let it sit for about 5 minutes and then wipe it off with a micro fiber towel. it even works on the chrome and polished aluminum.
chopfather is offline   Reply With Quote
Bug and Guts......... - Similar Threads
Wraith with yeti guts Cork Axial Wraith 3 07-30-2015 11:25 AM
Swaping servo guts robertjpjr Electronics 1 05-05-2015 07:22 PM
Wraith Guts in an SCX Axle? Help..! Big Tex Axial SCX-10 7 10-15-2012 12:52 PM
Guts - Glory - Rata's Ram Rataplan Scale Videos! 0 08-14-2012 03:21 AM
Goat Guts! SteelHead Tamiya Txt-1 and Juggernaut 1 08-22-2004 10:23 AM
